Thread: Zx14r 2013 tire selection for track day.
Created on: 02/15/17 09:36 PM
Dani
02/15/17 9:36 PM
Hi all,
I would be goin to my first track day on march the next month.
I have the stock tires bridgestone battlax 120/70 58w 17
190/50 73w 17
.i am wanting to upgrade my tires to the pirelli sc2 for both front and rear.
And am looking to upgrade my rear to 200/55 instead of 190/50.
Would there be any change in bikes geometry or riding , because of the difference in height of tires ?
RE: Zx14r 2013 tire selection for track day.
02/15/17 9:52 PM
Yeah, it will turn in a lot easier. Might take a few days to get used to it. I find it much preferable to stock. Replacement tire is a 190/55 (think that was it but I know it was taller than 190/50) so what they give you stock is not really what the bike was made for. No problem at high speed with a 200/55.
Make sure that 200/55 will fit your swing arm. I have maybe an extra 1/4" wheel base because I have an extra link in my chain. Pirelli 200/55 was very close for me.
02/15/17 9:53 PM
You will find it more of a challenge to clean the chicken strips off of a taller rear tire if that's any concern.
Dani
02/15/17 10:06 PM
Can the same stock rims be used for 200/55 or should i change them ?
02/16/17 7:46 AM
Same rims are fine. Riding off the edge is the problem no matter the wm/diameter/etc.
Dani
02/16/17 10:25 AM
hub
What do u mean riding off the edge ?
TRAILBOSS
TRAILBOSS's Gravatar
02/16/17 10:51 AM
Your proposed tire sizes are valid. 200/55 will give you more agility by changing your geometry a bit. The wheels will handle those sizes as well.
More concerning is your actual tire choice. Which tire are you using? SC2 is a compound used for the Superbike Slicks and the Supercorsa SC series DOT race tires. Both of these are racing tires, designed to be used with warmers. If this is your first track day, I sincerely doubt you'll be working the tires hard enough to keep them at operating temperature, which will likely result in them performing worse than street tires.
A far better Pirelli for your application will be the Supercorsa SP. This is their highest performing street/track tire, and offers significant levels of grip and stability without the need for warmers or expert pace. Same sizes to meet your needs as well.
02/16/17 11:10 AM
pretty sure the first number is the width of the rim from bead surface to bead surface. 190~200 is just 5mm/side. Makes no dif in how well the tire seals. A 190 wide rim will squeeze a 200 tire a little taller in addition to the approximate 10mm larger diameter from going from 50 to 55. it probably raises the rear about 8~10mm overall. Makes a real difference in how the bike handles.
* Last updated by: Rook on 2/16/2017 @ 11:11 AM *
WillsZX14R
WillsZX14R's Gravatar
03/16/17 7:50 AM
Dunlop Q3 are amazing tires for the track too.
david5525
david5525's Gravatar
03/16/17 11:16 AM
I have been running Q3s at the track too, but you cant get a 200/55. Comes in 200/50 which doesn't get you really any difference from the 190/55.
I am also looking to go to the 200/55 so will probably be getting the Supercorsa SP to try out this year. More expensive and I here it wears faster but also a better tire.
TRAILBOSS
03/16/17 12:02 PM
If you want max grip out of a street tire and don't mind the cost of replacing often, the Supercorsa SP is the best tire you can buy for the 14R. The softer carcass, huge contact patch at lean, and sticky compound all work together to add planted confidence and big grip on drives.
The Q3 is a great street tire for the 14R, but I found it to be lacking at the track when I really started pouring the throttle to it. Big unpredictable slides on the drives. Lots of feedback otherwise due to the stiff carcass, just not where it mattered to me.
WillsZX14R
03/17/17 6:23 AM
I'd love to slap on some Dunlops Q3 on my 14R chomp on the apexes.
TRAILBOSS
03/18/17 4:04 PM
Just keep the traction control on, or a spare set of plastics for the impending highside!
WillsZX14R
03/18/17 6:08 PM
lol yeah, gotcha. probably would want to stick those race plastics before unleashing the dragon.
Dani
03/21/17 1:33 PM
Thanks for all your input guys .
200/60 was the rear tire sc2 slicks.
Had a great time at the track , could push it to limits and it wouldnt let me down at all honestly :)
WillsZX14R
03/22/17 6:19 AM
for me, sticking with the stock size works for me..
03/28/17 4:08 PM
ooo. not me.
TRAILBOSS
03/29/17 12:52 PM
ooo. not me.
Agreed. There's a perceptible difference in handling and traction on drives wth the larger rear. On street rides it's mostly for an extra margin of error, but on the track you'll use that agility and traction.
03/29/17 8:47 PM
Simple question, yes or no answere please.
Will the Pirelli Supercorsa SP 200/55 clear the swingarm on my stock '14 14R without a smaller sprocket or longer chain?
Thanks!
TRAILBOSS
03/30/17 8:17 AM
Yes.
I had the same exact tire and bike. You're good.
03/30/17 12:26 PM
Si el jefe
* Last updated by: cruderudy on 3/30/2017 @ 7:59 PM *
TRAILBOSS
03/30/17 4:35 PM
De nada mi amigo!
